Re: 94 camry 2.2L Crankshaft Bolt
As long as the timing belt is still installed, you can loosen it by removing the primary coil wire, then wedge a breaker bar against the front crossmember and turn the ignition key for a split second to "bump" the engine...works like a charm.
Reinstalling isn't as easy...you can't "bump" the engine in reverse, and rotating the engine counterclockwise is highly inadvisable. I used a large strap wrench around the crankshaft pulley and wedged it against the right side subframe. Holding the strap wrench stable, I was able to tighten the pulley bolt. But I'd suggest using safety glasses and shop gloves...there's gonna be alot of tension in that strap wrench when you're done and have to remove it.
I tried to use the "screwdriver wedged into the flywheel" trick through the starter hole, but couldn't find anything to stick the screwdriver into. If you can get this to work, it's a safer alternative to my solution. Good luck!
Current Garage:
2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
