SludgeRASPUTINSS55 08-06-2008, 02:11 PM Whats the best way to remove sludge from engine,I got like about a half inch of the crap under my valve covers.How bad does this affect performance ?My mama said stay away from used cars. inafogg 08-06-2008, 03:58 PM HELLO,best to remove buy hand while covers are off.not sure what its called but you can buy a cleaner addative to flush.GOOD LUCK RASPUTINSS55 08-06-2008, 05:24 PM Thanks angus10 08-06-2008, 05:46 PM I would just carefully remove what you can by hand! And just use good quality detergent oil . If you flush it you will be risking leakes and possibly clogging the oil pick up screen. inafogg 08-06-2008, 11:06 PM good point angus!!if its not effecting anything now maybe a few oil changes would be good info i was thinking it has already caused problems. jdmccright 08-07-2008, 04:34 PM I'd check the PCV valve to make sure it's working. Sludge inside the cover usually means sludge in the PCV. Automotive Network, Inc., Copyright ©2012
