Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 08-06-2008, 01:42 AM   #1
deesandvees
deesandvees's Avatar
deesandvees Normal reputation
Early-mid 90's serpentine alternator bracket?
I've got the alternator/ps pump bracket that fits the smaller size alternator and have been trying to find a bracket that allows for the larger alternator.
smaller alternator bracket (this picture is one that's converted using aftermarket brackets to fit on a big block but the bracket is the same as the one I have now):
Larger alternator needs different bracket (note the mount positions are in the 180 degree area where as the smaller alternator mount points are closer to the 120 degree area):
yes I know this is not a serpentine alternator but it's just an example
Anybody know what I need to look for for to find the bracket I need? Was there an option for a larger alternator in the early-mid 90's trucks or suburbans that would have the bracket I need? Am I looking for something that doesn't exist?
'87 Landau
deesandvees is offline   Reply With Quote
Old 08-06-2008, 07:02 PM   #2
1968 Pontiac
1968 Pontiac's Avatar
1968 Pontiac Normal reputation
Re: Early-mid 90's serpentine alternator bracket?
I haven't tried it on my truck, but you might try the brackets from a 9C1 (police package) Caprice. They came in two flavours:
a small adapter arm that attaches to the small alternator/ps bracket
an alternator/ps bracket specifically made for the large alternators
I have both set-ups although I'm currently using the adapter arm on my 91 Caprice. What I did find was that one of the large alternators I have, which is the one that came with the bracket specifically made for the large alternator, will not work with the adapter arm set-up as the alternator has too large of a diameter so it fouls at the section above the ps pump and can't be dropped enough to be bolted to the arm. All of my large 9C1 alternators are Delco's, so the problem isn't a cheaply cast housing made out of tolerance.
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to a 1940's or 1950's Chev pickup when I find one)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
1968 Pontiac is offline   Reply With Quote
Old 08-10-2008, 02:27 AM   #3
Telco_Tech
Telco_Tech Normal reputation
The bracket that I think you want to use is Part # 10077589. I have one that I plan to use on my changeover from '89 to '90 brackets.
1989 Chev K1500 EC
1998 Firebird Formula M6
1969 Firebird
Telco_Tech is offline   Reply With Quote
Bookmarks
Google
Web AF
