Hose that sucks antifreeze into the engine burst!!!!94blazer4.3vortec 08-06-2008, 12:58 AM Hose that sucks antifreeze into the engine burst while i was driving it was overheating and the temp. gauge went up I pulled into a gas station to see if it was pissing antifreeze and it wasnt it was dripping so now all that is left of the hose is the part that runs from the top right part of the engine were ever it connected to is gone and i have no idea as to were it runs after it leaves the engine block and what it connects to could you PLEASE HELP.... I need to know AFTER THE HOSE LEAVES THE ENGINE BLOCK WERE DOES IT GO AND WHAT DOES IT CONNECT TO AND WERE WOULD THE CONNECTION BE... its not any of the big hoses its a 3/8 size hose that runs off the engine block and it sucks antifreeze into the engine PLEASE HELP!!! MT-2500 08-06-2008, 09:10 AM There is a small hose like 3/8 that runs from top of rad to the overflow tank. If overheating check out the overheating problem. Good rad cap and thermo stat? Rad low on coolant? Any other coolant leaks? 94blazer4.3vortec 08-06-2008, 10:45 AM Radiator cap good, thermostat good, not low on coolant.. coolant all gone because hose ON TOP OF ENGINE THAT SUCKS ANTIFREEZE INTO ENGINE BURST ALL THAT IS LEFT IS WERE HOSE RUNS OFF ENGINE.. I DONT KNOW WERE THE HOSE CONNECTS TO HOW TO GET TO THE CONNECTION!!!! MT-2500 08-06-2008, 10:56 AM If the tempt gauge went up it was overheating. The hose hooks to the bottom of overflow tank to the top of rad under rad cap. Is the hose off at one end or the other or just broke? On the overflow tank pour some water in it and see where the water runs out. MT 94blazer4.3vortec 08-06-2008, 11:43 AM Its not the overflow hose going from the radiator cap to the over flow tank all those things are good. ITS THE HOSE THAT COMES OFF THE TOP RIGHT SIDE OF ENGINE BLOCK WHEN I WAS LOOKING AT IT THE HOSE WENT IN A DOWN WARD DIRECTION IT DOESNT GO THE RADIATOR CAUSE I LOOKED AND CHECKED AND DIDNT FIND ANY CONNECTIONS ON THE RADIATOR... WERE DOES IT CONNECT TO???? mike2004tct 08-06-2008, 12:36 PM Its not the overflow hose going from the radiator cap to the over flow tank all those things are good. ITS THE HOSE THAT COMES OFF THE TOP RIGHT SIDE OF ENGINE BLOCK WHEN I WAS LOOKING AT IT THE HOSE WENT IN A DOWN WARD DIRECTION IT DOESNT GO THE RADIATOR CAUSE I LOOKED AND CHECKED AND DIDNT FIND ANY CONNECTIONS ON THE RADIATOR... WERE DOES IT CONNECT TO???? There are no 3/8" dia hoses on the block. 3/4" dia, yes. Those would be (2) the heater core hoses, running from the block/water pump, to the passenger side firewall. No need to YELL either. MT-2500 08-06-2008, 12:42 PM Post a picture. MT-2500 08-06-2008, 12:43 PM 94blazer4.3vortec 08-06-2008, 12:47 PM sorry for yelling but i am trying to figure out were this hose goes and its driving me nuts!!!! its not the 2 hoses that go to the heater core behind the passanger fire wall cause i was up until 2:30 a.m trying to figure out were this hose goes and i cant figure it out i looked all over the engine and the radiator and nothing... please help someone??? Leeann94astro 08-06-2008, 12:48 PM As MT has requested, post a picture. Without actually seeing what's disconnected, anything we might tell you is simply a WAG. 94blazer4.3vortec 08-06-2008, 12:50 PM Ok I'll try to post a pic soon... 94blazer4.3vortec 08-11-2008, 11:45 PM Thanks for the help guys but it wasnt the hose it was the radiator i didnt know i looked at it yes it took me this long to figure it out i couldnt post a pic cause the camera i have i lost the wires and could'nt post a pic sorry but im gonna go to the bone yard a get another radiator cause the radiator is leaking through one of corners were the hose connects to the radiator and it driped onto another hose and i thought it was leaking from the hose that was getting leaked on... MT-2500 08-12-2008, 10:07 AM If the rad is bad. Junk yard rad rad may not be so good. It is best to get a new one. Check you local parts places for price on a new one. Goodf Luck MT Automotive Network, Inc., Copyright ©2012
