95 Olds Problem
s281er238
08-03-2008, 07:36 AM
My 95 Olds Cutlass Supreme Hasa Wier Problem Everytime I Lock The Door And Then Wehn I Unlock The Driver Door Stays Locled I Have To Use A Key Once In A While It Will Unlock And Lock With All The Others What Can This Be And I Also Have The Abs Light Come One And Off Every Now And Then
Mikey_G
08-26-2008, 09:50 PM
My 92 Olds does the same thing. No idea what's wrong with it but give my other problems I ignore this one. Also, once in a while drivers side window won't go up again unless I put the car in park. Wiring issues seem pretty common with my vehicle. Replaced the turn signal switch twice already because a short was sending smoke out of the steering column.
xeroinfinity
08-28-2008, 12:42 AM
on the switchs if they are working correctly then I'd check the wires in the door frame where it opens, and the wires in the doors.
Wires can get britle of time are crack/break and cause all sorts of strange issues.
