Re: A/C Issues
Manifold gauges are better at trying to diagnose A/C problems as you can see the pressure difference between the high and low sides and how they change as the system runs.
That being said, my first guess would be that you have water condensate in the system and it is icing up in the accumulator and/or orifice tube or causing it to get clogged.
Easiest way would be to have a technician check it out, but if you're interested in learning, Haynes makes a decent repair manual specifically for A/C systems...it's info overload in the beginning, but very handy knowledge. Good luck!
Current Garage:
2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
