Re: wont idle good when cold
i looked like you said,and i do see the hose go from the booster line and the intake and also the valve cover, it looks to me like they tie together and go in to the top of the oil filter housing assembly,is the vacuum pump built into this assembly.also do you think the pump is bad, or a line. i checked for a vac.leak by spraying lines with carb.cleaner and did not find any. thank you so much
