Re: tire wobbles
TIre wobble, do you have any vibration in the floor or steering wheel. Even though a tire is round, it is not perfect, ie the reason for balancing. There will be a minor imperfections in the tire to make it look like it is "wobbling". IF you jck the tire up, and place a bar under the tire, lift up, and there is NO movement, and NO cornoer to corner play, then you are fine. If you jackit up and the tire just "flops" then you could have other issues, like abearing failure.
