Re: 97 Camry will not start when Hot!
Simple stuff? Tap on the starter relay and/or the starter when starting. Remove the starter relay and reinstall. That may clean corrosion off the pins. Jump start the car using jumper cables. If it starts, you have a battery or battery connection problem. Wiggle the gearshift lever while starting. This may convince a neutral start switch to cooperate. Make sure the battery connections both on the battery posts and the engine and chassy ground studs are clean and tight. Wiggle the battery cables while starting. They can fail internally with no visible indications.
If you have experience with a meter and schematics download the starting system schematic in your factory maintenence manual found at the top of the forum under "Factory Service Manuals". Start by determining if the coil in the starter relay is getting voltage when you turn the key. You can probably figure it out from there. If not, come on back.
No experience? Find the starter relay in the fuse box under the hood on the driver's side fender wall. It may be labeled "ST Relay". Put your finger on the relay and turn the key:
> If you feel it click, you may have another bad starter, or loose/corroded connection on the starter, fried contacts on the relay (change it), or broken wire from the relay to the starter.
> If it doesn't click, your ignition switch, neutral safety switch, or engine computer could be bad. Another possibility is if your Camry has a Theft Deterrent system. If equiped, it supplies the ground for the starter relay coil.
Unfortunately for such a simple system, there are many things that can create a no rotation issue. It just takes a process of illimination to find the culprit.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
**DIYer and multiple automotive forums junkie for years. Air Force career in aviation electronics.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan / 94 Camry
