99 ford escort a/c problemrub6dan 07-29-2008, 07:14 PM my son has this car and the ac doesnt work. i checked the fuses i checked the a/c pressure on low side it is 45psi i jumped the ac clutch on the blue wire it came on and blew cold. so any ideas why or where i should look for the clutch is not coming on with the switch. AzTumbleweed 07-29-2008, 08:51 PM On a '93 there are two relays. jamesmetairie 07-29-2008, 08:59 PM i have a 1999 escort lx sedan. had the common a/c problem. searching around ,mostly this forum i discovered the "cold solder" problem. == below your air filter container is the location of the ccrm=constant control relay module(black box). first you need to drill the rivets to get into it.in it there,s a relay that is messed up laying on the little computer looking board. i bought the exact same relay at radio shack for about $3. and a friend soldered it in there for me. used tie-wraps to secure the ccrm back together. then the a/c works perfect. try searching this forum for more info and if i find my radio shack part # i,ll pass it on. jamesmetairie 07-29-2008, 09:05 PM BTW =- the dealer does not sell the relay. they only sell the whole ccrm box for a few hundred $$. GTP Dad 07-30-2008, 07:55 AM Welcome to AF!! As jamesmetairie says the CCRM is bad and needs repaired. Search the forum for threads concerning the repair. It is not hard to do and takes longer to get it out of the car and drill out the rivets than it does to fix the bad spot with a little soldier and an iron. I repaired mine and it works just fine. Fixed it two years ago. If you can't find the information post again and we will help you out. mightymoose_22 07-30-2008, 03:59 PM Could be a bad cycle switch. I believe it is located on top of the dryer. Davescort97 08-02-2008, 02:57 AM It could be the low pressure switch, but I would be looking at the CCRM. tripletdaddy 08-02-2008, 04:24 AM If one were to jump at the connector to the low pressure/clutch cycling switch with the ac switched on inside, and it comes on, it may be the switch. The low side pressure needs to be 45 psi or higher before the switch will allow the compressor clutch on. It should be plenty high when off and hot out for it to be above 45 psi. If not, it won't work. If jumping doesn't work, you're looking at the ccrm. I suppose if you are smart enough, you may be able to wire in a generic relay in place of the one in the ccrm. Does the fan come on when you turn on the ac, but just not the clutch? Automotive Network, Inc., Copyright ©2012
