Originally Posted by ChevyBobby
Does anyone know what the GFT code means? It is for my 1999 3500 crew cab Pick up.
And can I get an electric inline fuel pump for a back up so I do not get stuck on the road somewhere.?
That is the code that the parts store needs to give you the correct pump.
As for a backup pump, I have no idea if it will work. But maybe you could set it up "out of line" with a valve at the inlet to get you home. Need to be carefull with the pressure.
