Secondary Air Injection Pump Problemwiedzmin 07-28-2008, 11:36 AM Hi, Please I need your help. I have 02 Intrigue. I got the SES light went off a couple of months ago. I checked the code. Ofcourse it was P0410. So I did change the air pump ($80 refurbished) and the hose assembly. But the problem didn't go away:mad: . So in my next step, I bought a relay for the pump but I don't know where is located :uhoh: (is not in the fuse box). Do any of you guys know where it is? I'm hoping that when i replace it the problem would be solved LittleHoov 07-29-2008, 01:24 AM By fuse box, do you mean the one inside the vehicle on the passenger side? There is also an underhood box that has most of the relays in it, its also on the passenger side under the hood. California emission equipped vehicles will also have another small box next too it with a few relays in it. wiedzmin 07-29-2008, 03:13 PM I only checked the one underhood on the passenger side. thanks I'll check it out vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
