Alrighty, I've got a two things that I'm wondering about my car...
1. When can you tell you have to replace a coil spring? I know my strut needs to be replaced (rear) but I was wondering about the coil...car is a 99 and it has 130 000 kms on it and I'm pretty sure the coils are the original ones...
2. How many grease fittings are there? I just found two (near the ball joints) annnndd one of there was bursted....o joy...guess I'll have to replace it...if I dont do it, what's the worse that could happend?
3. My wipers seam are starting to act up...sometimes when I turn them off they simply keep going for some reason....they also stop a sit about 3-4 inches higher then they should normally. Haynes mentions that the switch could be defective. I was just wondering what they meant by "switch". Is it inside the motor or is it the arm on the right side of the steering wheel? Also, if it's the one on the steering wheel, can I install one with an adjustable delay time if I had a non adjustable one before? (I could get one for almost nothing but I just want to know if it'll work before getting it)
Thanks to anyone who reads/answers this!
