2000 jimmy electrical problem - dash and runjdbeck 07-27-2008, 05:51 PM Hi All, Need a bit of guidance on this one. I have a 2000 Jimmy and am having an intermittent problem with shutdown while driving ( usually after a longer run ) Engine just dies out like someone shut off the key. May start immediately, may take several cranks, occasionally requires a "rest" before restarting. 2nd problem. I noticed while driving this bear (belongs to the in-laws) that there seems to be some electrical problems in the cluster / gauges. On high idle, or a steady throttle pressure, car in park, the speedo will climb to about 4mph and then drop back to zero. At a stop, turn signal on. the voltmeter pulses in time with the signal. Finally, the fuel gauge is all over the place. ( am thinking a bad sender here) The folks had the coil replaced on a recent trip when the shut down reared it's head. no joy there. still does it. There are no codes set and i have run a road test with a reader attached. no luck there. I've been readign back threads, and am thinking this whole mess is involved with the ign harness problem. I appreciate any guidance you can give! Thanks ! jeff Beck Cumberland, MD MT-2500 07-28-2008, 11:00 AM Check for lose of spark or fuel pressure when it quits. Post back results. Also Check all power feeds into and out of fuse boxes. A check with a good engine capable scanner may show a problem. Good luck. MT Automotive Network, Inc., Copyright ©2012
