Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 07-25-2008, 11:05 PM   #1
thonda1
thonda1 Normal reputation
)2 sensor heating problem!!!
I have a 2000 Honda Accord LX 4cyclinder sedan. My check engine light has been reading a p1167 code, which is the 1st circuit heating system o2 sensor problem. After buying an aftermarket o2 sensor, and then eventually a honda o2 sensor, the check engine light is still on. I figure it is the wiring, but if anyone knows what else it could be would be great help
Also, I am unsure as to whether or not this problem is causing my heating gauge to move towards the red when i remain idol after driving for a while. I don't think it's actually overheating though, because the engine drives like normal even when it says its overheating.
thonda1 is offline   Reply With Quote
Old 07-28-2008, 11:22 AM   #2
somick
somick's Avatar
somick Normal reputation
Re: )2 sensor heating problem!!!
I think you have two different problems. If your O2 sensor is the right one and you installed it correctly you should try to reset the check engine light.
For the overheating issue try to bleed your cooling system from all the air. Make sure your thermostat is working.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
somick is offline   Reply With Quote
Bookmarks
Google
Web AF
