'95 Ranger air bag code 33 ??jostby 07-24-2008, 08:15 PM Can anyone help? I'm not finding much on google or by doing a search here (maybe because less than 3 letters?) Thanks, Jeff. jostby 07-24-2008, 08:26 PM OK, this looks like kind of a generic list. If it applies to my '95, where would the "diagnostic monitor" be? Thanks again, Jeff Air Bag Fault Code Table | 12 Low Battery Voltage | 13 Air Bag Circuit or Crash Sensor Circuit - Shorted to Ground | 21 Safing Sensor - Not Mounted on Vehicle Properly | 22 Safing Sensor Output Circuit - Shorted to Battery Voltage | 23 Safing Sensor Input Feed/Return Circuit Open | 24 Open in Circuit 944B or Low Resistance in Crash Sensor(s) | 32 Driver Side Air Bag/Safing Sensor Circuit - High Resistance or Open | 33 Pin 7 Not Grounded at Diagnostic Monitor | 34 Driver Side Air Bag/Safing Sensor Circuit - Low Resistance or Shorted | 35 Low Resistance Across Pins 8 and 9 at Diagnostic Monitor | 41 Crash Sensor Circuit - High Resistance or Open | 44 RH Crash Sensor - Not Mounted to Vehicle Properly | 45 Center Radiator Crash Sensor - Not Mounted to Vehicle Properly | 46 LH Crash Sensor - Not Mounted to Vehicle Properly | 51 Diagnostic Monitor Internal Thermal Fuse - Blown and Short to Ground No Longer Exists | 52 Backup Power Supply - Voltage Boost Fault | 53 Internal Diagnostic Monitor Fault Lowest -- Rapid Continuous Flashing of Air Bag Lamp - All Crash Sensors Disconnected Automotive Network, Inc., Copyright ©2012
