Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-24-2008, 12:33 PM   #1
onceagen
onceagen Normal reputation
Smile '98 Camry power windows not working?
Dear All,
During the winter I more than once was faced with '98 Camry power windows that wouldn't go back up. It turns out that the car battery needed replacement. I put in a new battery and the windows have been fine ever since. Hope this might help someone with problem windows or to recognize a bettery that's on the way out. Ed
onceagen is offline   Reply With Quote
Old 07-25-2008, 01:07 PM   #2
somick
somick's Avatar
somick Normal reputation
Re: '98 Camry power windows not working?
Thanks for posting. It may help somebody!
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
somick is offline   Reply With Quote
Old 06-18-2009, 07:29 PM   #3
khai_kohokoho
khai_kohokoho Normal reputation
Hey !!
I have a 96 camry. Its driver side power windows does not go back up as yours. Could this really be the battery problem ? Coz' everything else which requires battery works very well. is there any other solution you know ?
khai_kohokoho is offline   Reply With Quote
Old 06-19-2009, 12:23 PM   #4
Mike Gerber
AF -Advisor
Mike Gerber Normal reputation
If the passenger side windows work normally, then the battery is not your problem. You could have a blown fuse, a bad power window switch, a defective power window motor and/or regulator, or even a wiring problem in the harness leading in to the front driver's door. You have to do some testing to figure out which of these items are causing your problem. If you are not familiar with how to check these systems out, you will probably be best served to leave this to a professional.
Mike
Mike Gerber is online now   Reply With Quote
Old 06-19-2009, 12:56 PM   #5
khai_kohokoho
Mike
i too think that it's not a battery problem. will try to take it to a professional. one more question. is there different motors for each of the four windows or only one motor in the switch panel controls all four windows? how much could a motor and/or a switch panel cost (in a junkyard) ????
thanks !
Old 06-19-2009, 09:54 PM   #6
Mike Gerber
AF -Advisor
Each window has it's own motor and regulator. Prices will really vary depending on whether you go with Toyota OEM (most expensive) or aftermarket. Aftermarket prices can also vary a great deal. Some people use online sources for parts like Rockauto.com or even Ebay; but you usually have to be able to do the work yourself to take advantage of those places. Independent shops want to furnish their own parts for 2 reasons; 1. They make a profit on the parts and 2. They have to be able to guarantee their work, because if it comes back they have to do the job again for free.
Mike
Old 07-06-2009, 11:59 AM   #7
superdesi
superdesi Normal reputation
1997 Camry power windows not working also.
I've got the same problem on a 1997 Camry. Door locks work fine. However, the power windows do not work from the Driver's Side Master Window Switch and also do not work from the switch at each window.
I don't think the battery is the problem since it starts up fine. I think it more probably a fuse.........but I just can't find out which one.
None of the windows work.
- 1993 Sentra E Coupe
- 2005 Chevrolet Malibu
- 1999 Chevrolet Suburban
- 2003 Town Car Signature
superdesi is offline   Reply With Quote
Old 07-06-2009, 02:59 PM   #8
khai_kohokoho
Mike
I recently changed the interior and exterior door handles of driver's door (they were broken), and inter. handle of rear passenger side. read instruction over the internet. took a bit time but was really satisfied. I feel I can change the motor too. I'm looking for some cheap window motors(junkyards and ebay).
Old 07-06-2009, 08:51 PM   #9
Mike Gerber
AF -Advisor
I'm not a big fan of junkyard electrical parts, especially when there is quite a bit labor involved in installing them. Once again, I would stick with your local parts store, RockAuto.com or ebay.
Good luck.
Mike
Old 07-07-2009, 12:52 PM   #10
jdmccright
The RustBuster
jdmccright's Avatar
jdmccright Normal reputation
Send a message via MSN to jdmccright
I've gotten new window regulators with motor for about $65 from eBay. Just double check that it isn't the driver's door wiring harness. All that flexing from opening and closing can fatigue the wires inside the loom. Sometimes you can pinch and roll the rubber sleeve between your fingers to get intermittent contact...try different door positions too. Good luck!
Current Garage:
2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
jdmccright is offline   Reply With Quote
Old 09-08-2009, 10:13 AM   #11
james11109
james11109 Normal reputation
I have a 96 camry, the driver side window had a similar problem 3 years ago,
it could not go up/down occasionally during winter time. Finally, I solved
the problem by replace a new regulator, which cost CN$90.
I also did some research on the old parts, opened the motor, I fund that the
actual problem is caused by the lubricant oil covered on the electric terminals,
it make a high resistance on the current inside the motor. After cleaning the dirty lubricant oil, and putted the motor back, the regulator was work well.
due to the store had no return policy, I am now still use the new one in my car, but I still keep the old regulator with me.
james11109 is offline   Reply With Quote
Old 09-08-2009, 06:00 PM   #12
ice745
AF -Advisor
ice745 Normal reputation
If you're doing the work yourself and already have the door panel off, you may as well throw some lubricant on the track. I believe I've heard of people using graphite, but I just used petroleum jelly and it worked great for me. You can tell it makes a difference and helps the motor move the window easier. Lubing the track probably won't fix a completely stuck window (that's probably a dead motor or switch), but it's definitely helpful if the window is draining too much power.
Smoking is bad... especially blue smoke!
Fill the oil and check the gas, please.
ice745 is offline   Reply With Quote
Bookmarks
Google
Web AF
