Re: 1990 Accord shutting off/not starting sometimes
The main relay powers the fuel pump and ECU so it could be the problem. It has been reported before. Usually the problem is cold solder joints on the circuit board. It can be repaired/resoldered and is the first place I would start. The other problem could be the IGM and/or coil. and they are more of a substitue and see if it fixes the problem then troubleshooting because it only happens when the engine temperature is high.
