Originally Posted by amplifier28
i have a 2000 Cavalier. A/C not blowing through front vents and blows through bottom of dash. is there a vacuum leak?
I know this is an old thread, but I just fixed my 2003 that had a similar problem with the HVAC control. It's a common problem - the control knob turns but you can't get air through the defroster or floor - only through the dashboard vents.
The problem is a cable that runs from the back of the control knob to a mechanical assembly inside the dash the directs the air floor to the different vents. The mechanical assembly is a plastic wheel moved by this cable. The plastic wheel in turn moves plastic levers that open and close various flaps that block or open vents. Over time these levers become hard to move - the surfaces get rough or their hinges dry out, needing a harder push by the cable to move. This puts stress on the cable that eventually gets a kink where it attaches to the control knob.
To fix this you need a new replacement cable you can buy from the parts counter at a Chevy dealer for $25. Then pay $90 to have it replaced. I did it myself - it required a lot of effort to see where the cable attached high up in the dash, then squeeze my hand up there to attach the cable. But the problem is, the cable will likely kink again unless you get those levers lubricated. I did that by using a white grease spray cans that had one of those tubes you attach to the nozzle. It was a tough job to get the can up there, but with persistence I did. I don't know if a mechanic at a dealership would go to that amount of effort.
So the fix cost me $25 plus tax and a Saturday afternoon.
But that's the fix. You can try to repair the cable by using pliers and straightening the kink in the cable. We tried that. But it's now a weak point in the cable and will kink again in a short time.
This is a royal pain in the ass to try to try to see what you have to do then get your hand up there to do it. But it's unsafe to drive around without a defroster and cold feet.
I've got photos if you need them.
Mark
