Re: Wont Start Please Help
If its not starting, and you have checked teh timing, then the next thing would be to look at the compression of the cylinders. If there is no- or little compression it will not run on that cylinder. Right now, if you pull the plugs out and they are wet, remove all of them then disable the fuel pump and crank teh engine over (with plugs out) this will help get rid of the excess gas thats built up in the cylinders. Once its clear, then installthe plugs and re-enable the fuel pump. Try to start it, if no luck ,check the compression. THe cylinders should be about 90-150 psi.
