2002 Blazer LT shutting off.kev62 07-20-2008, 08:49 PM Trying to determine why my 02 Blazer LT is shutting down on me, even while i'm driving. Had it to a dealer and put on a computer. Still unable to find the trouble:confused: Anyone experience this problem before? MT-2500 07-21-2008, 08:29 AM Soner or later almost everyone will have a problem like that. What engine and mileage and service history? Any check engine lights? Did you dealer not check fuel pressure and for lose of spark when it shuts down? Or did they just read codes and give up? Sounds like the dealer had the grease monkey check it. Tip on going to the dealer Ask that only a factory certified gasoline engine performance specialist work on your car. Not all dealerships are concerned with how repairs are dispatched, and not all dealership techs bother to take advantage of the training offered by factory (the vast majority of which is paid training). If the dealer is uncooperative, ask for your money back and call around for a dealer that will accommodate you. To find the problem hook up a fuel pressure gauge and drive it untill it acts up or quits. When it quits you need to check for lose of spark or fuel. The only true test on a fuel pump is to check the direct fuel pressure from fuel pump. A quick test is to block off the return line and see if fuel pressure comes up to 75-85 lbs. But do not run the pump at full pressure very long. Also when testing fuel pump and pressure you need to tape a gauge to outside windshield or outside mirror and drive it on the road for 20 -30 minutes until the pump gets has run a while to check for a pump fading out after hot. Hard to start cold or hot and fuel pressure testing guide lines. Check cold start fuel pressure. Check engine running fuel pressure. Check engine running on the road fuel pressure. Then shut it off and watch for fast leak down. Pinch off at rubber part or block off return line and check full pressure. If pump has full pressure with return line blocked and low pressure without it blocked most usually the fuel pressure regulator is leaking or not holding pressure. Later V6 and V8 gm engines should have 60-66 fuel pressure. Cold start should be 64-65 lbs of pressure. If you do not have full fuel pressure on a cold start the injectors will not squirt fuel. Do not leave home without it. Engine running should be 60-66 lbs pressure depending on engine load. Full pressure with return pinched off should be 75-85 or more. And if it has a fast leak down after shut off you have a leak in system. Post back fuel pressure readings. Automotive Network, Inc., Copyright ©2012
