Re: 99 civic wont start
if you bought your starter from a chain parts store, it does not mean it works. i had 3 alternators installed out the box in one evening, as 2 of them were no good.
the whining noise is coming from altrnator gear not engaging with the flywheel. it just spins, and when it spins, it goes into very high rpms, thus the high pitch noise.
thus, i am assuming that thing known as "bendix", or solenoid that pulls the gear out and into the flywheel, is no good.
if you have absolutely positively good starter, and car runs from push-start, then it's your flywheel. ONE chipped tooth can do that. solenoid does not have seperate power feed, so you can't blame it on a bad contact.
if you know what you doing, try smacking solenoid with hammer HANDLE. no metal. tap it several times rather vigorously. see what happens. old men's trick.
maybe somehow starter bolts went out of kilter and gear is not engaging right.
