05 Civic Ex, Camshaft Position SensorPOYSN1 07-18-2008, 07:25 AM Where Would I Find Them In An 05 Honda Civic Ex? Please Help... Send Me Message If U Now How I Can Find It Please.. Maple50175 11-26-2008, 12:37 PM For safety disconnect the battery, losen all drive belts,including alternator from the top screw if you reach it from the upper side with a 12 MM socket or wrench,then take off driver side front tire, remove two plastic pins from the engine splash guard with a 10 mm socket or wrench, get the splash guard down, now you support the engine with a hydraulic jack (I will recommend to use a piece of flat board of wood or plywood in between jack and engine) and put a jack stand on where removed tire, now take off Lower engine mount with a 14mm socket or 9/16, since we have supported the engine with a jack possible get off the upper left (driver side engine mount,so we will be able of moving up and down the engine since we will remove three screws of the bottom part of the timing belt cover, plus de AC idler pulley,but before that we also could start taking the belts off the crank shaft pulley,which is the pully where all three drive belts go to, this pulley there is only two ways to get it out since on Hondas they do come so thight, one is with the air gun, second is using a vice grip with a chain on the tip and thight it well and hold it very strong while some one tries to get it out with a very stron rachet and 3/4 socket or 19 mm. is recommended to use long extensions on the rachet, once you get the pulley out get the screws off the timing belt cover but just the lower part of the cover 3 10mm screws,plus remove the ac idler pully which is the small pulley on the midle of the lower part of the cover once you get the pulley out you get the cover out, and follow the cable that comes down by the oil pan and remove the screw of the golden angle that ends right on the left of the timing belt for and easy assambly of the new sensor is better to remove the other screw on the little angle of metal, just follow the same rod for the wire and that's it, connect it, put the cover back, install all drive belts in position and insert them on to the crank shaft pulley, and thight it good including belts, cover it back and you set the engine mounts back on set your tire back get the Jacks out plug your battery and done.!!!! Automotive Network, Inc., Copyright ©2012
