Right now I could say the problem is the wiper switch you should try to take it apart, and just for driving the car pop the cap for the whole wiper blade and unscrew them and disconnected the washer fuild main hoses.
As for the wipers, there must be a short grounding the circuit somewhere...possibly a faulty switch. I would start by pulling apart the steering column and take a look at the switch. There may be something obviously wrong, you may be able to fix it or not, but one from a scrap yard should work OK. In my experience that is the way to go. Probably expensive for a new one, and you probably can't fix it if it is broken.
well the low oil light and the low coolant light stay on constantly, but oil and coolant are full. I had the codes read once for the SES light and it said the second 02 sensor, I think.
