Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup / Ram SRT10
Old 07-15-2008, 07:59 PM   #1
jsledge
jsledge's Avatar
jsledge Normal reputation
when should I shift for the best gas mileage
just bought a 98 v6 5 speed manual. No RPM gauge. When should I shift gears.
thanks
Jim
jsledge is offline   Reply With Quote
Old 07-16-2008, 12:12 PM   #2
jdmccright
The RustBuster
jdmccright's Avatar
jdmccright Normal reputation
Send a message via MSN to jdmccright
Re: when should I shift for the best gas mileage
My truck has a shift indicator light, but it was disabled by performing some secret sequence. You might see if yours has been as well, or maybe just the light bulb was removed or burned out. It should illuminate with the IP test when you turn the ignition on.
If not, then it's going to take some practice and getting used to your truck's power band...feeling when the truck is or isn't pulling and listening to the engine. If you upshift and find you have to press the pedal down alot to keep the truck moving, then you shifted too soon. Likewise, chugging up a hill in higer gear will probably take more gas than downshifting since the pedal is not depressed as far.
On a flat road from a stand still (I'm going to presume you have the NV3500 5-speed tranny like me, but could be the AX-15), I can shift out of 1st fairly fast, less than 10 mph. Some will skip 2nd and some will start out in 2nd. My truck tends to lug starting out from 2nd gear. I'll shift to 3rd by about 20 mph, then 4th around 25 mph, and 5th at 35 mph. I have a V8, so I tend to skip 4th gear.
In general, the slower the engine rotates (use your ears) and the less you press down on the gas pedal, the better your fuel economy will be.
You could also buy an aftermarket tachometer (www.scangauge.com is an EXCELLENT tool for mileage and engine monitoring) that plugs into yout OBD-II port. Hope this helps!
Current Garage:
2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
jdmccright is offline   Reply With Quote
Bookmarks
Google
Web AF
