Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Jeep > Cherokee
Old 07-15-2008, 03:31 PM   #1
gorman90xj
gorman90xj Normal reputation
90 xj 4.0 engine light on when in 4wd
when i was in 4wd the other day i noticed the engine light came on, when i disengaged 4wd it went away.....were the problem could be i dont know...any ideas will be helpful...thanks.
gorman90xj is offline   Reply With Quote
Old 07-17-2008, 10:49 AM   #2
bondo07
bondo07's Avatar
bondo07 Normal reputation
Re: 90 xj 4.0 engine light on when in 4wd
You could have a vacuum issue. The front axle is engaged with a vacuum line. There might be a leak in the line. Did you check if your axle was engaged at all? Other than that I'm not sure. May just be some wierd computer issue. I wouldn't worry about it.
bondo07 is offline   Reply With Quote
Old 07-19-2008, 07:12 AM   #3
gtmud
gtmud Normal reputation
A vac problem is possible, The "engine" light came on when a code was set, if you can, try to retreive the code(s) to better get an idea of what is happening. Did anything change when you were in 4wd. Was everything working correctly?
gtmud is offline   Reply With Quote
Bookmarks
Google
Web AF
