power window problem
tullaroan
03-10-2003, 09:22 AM
My 2000 Xterra driver window has become very loose and I feel that it may have come off track (?) When driving with it partially open, it rattles and needs to be tightened up. Any suggestions as to what this problem is and how to fix it?
Schludwiller
03-10-2003, 09:35 AM
You'll probably need to pull the interior panel and tighten the window regulator.
tullaroan
03-10-2003, 09:42 AM
Thank you for your reply. I figured that this was likely the problem. Any suggestions where I may be able to find more information regarding the window regulator? Just want to do this once and do it right. Thanks again!
Schludwiller
03-10-2003, 02:46 PM
Probably only the service manual. You might just need to tighten the parts that hold onto the window. I guess I would pull the interior door panel and take a look. (watch out for snapping those plastic pins they use).
nflxterra
03-10-2003, 08:15 PM
I just posted a problem with my window regulators being replaced. Since October 2002 I've had 3 of my winow regs replaced the 2 front ones in October, driver side rear last thursday, they are telling us that a clip is breaking so they have to replace the whole assembly and it is not covered after you're warranty runs out as it is not a recall problem yet, also anyone in warmer conditions is supposedly more at risk, I would check it out. Mine started out with the windows going up or down slowly then rattling and grinding and eventually not working at all.
ChuckH
I thought they all rattled when not rolled up all the way? All of mine rattle and Xterra and Fronteir owners across the land have complained about this.
nflxterra
03-11-2003, 04:34 AM
yeah they rattle, but these rattle all the time, up down it didn't matter and it sounded like glass on sand when you would roll them up or down in any case 3 are fixed and one i'm going to roll up and down until it goes out before my warranty does.
BIGDAWG69
05-11-2003, 11:29 AM
2001 Xterra - All four of my power window motors have had to be replaced. First it was the drivers side and then two weeks later the passenger side went out. The dealer checked the two back windows when they replaced passenger side, they replaced all three at once. Dealer told me that Nissan was supposed to have a recall on all 2001 Xterra power window motors.
nflxterra
05-13-2003, 09:18 PM
isn't that a drag about the window regulators? i hope they do recall them, even though i've had 3 of mine fixed the fix is only good for 12months or 12k miles so that will be out of warrant soon, and i really don't feel like paying to have them fixed.
does anyone know how hard it would be to convert the power windows to a manual window?
Aythya
05-16-2003, 11:22 PM
Not that Im glad to hear that others have had problems but Im glad to know that im not alone. I am surprised to see this number of complaints about the windows though. Hell, mine have been rattling like crazy since about 8K miles. I mean to the point of being scared to roll them down half way.........Hell they look like they're going to break off....
I think I'll visit the dealer......broken clips might explain some of those first few rattles that I heard.........
take care~!!
fialdj
09-28-2003, 08:05 AM
I found this on the NHTSA website. We can complain about our troubles. I filed mine today.
http://www-odi.nhtsa.dot.gov/ivoq/
Dave
mtigger3
11-20-2003, 03:09 PM
I have a 2001 Xterra and am having the same issues with the power windows. The dealership told me that the weather strip has to be lubricated once a year to keep the regulator from breaking. I questioned as to why it wasn't in any manuals and they stated that it wasn't known until after the manuals were printed. I was told to call 1-800-nissan1 and to open a file that nissan tracks for possible problems that will require a recall. Hopefully if enough people call in and complain, the window will become a recall.
Volleydog
12-18-2003, 12:39 PM
My windows, rear ones especially, have been gradually getting harder to put back up as well. A buddy of mine at work had the same problem a few months back with his driver window, which eventually got stuck down. Right now his X is in getting the other 3 window regs replaced.
How can Nissan not turn this into a recall issue with so many having the same problem? This is clearly faulty/poor manufactuing on their part. Anyone who has not already done so, PLEASE use the above number to report your problem to Nissan.
OffroadX
12-22-2003, 04:11 PM
Good news, they are finally doing something about it:
Technical Bulletin (TSB) #NTB03-118
Campaign #PU306 & PU307
Notices should be going out this week.
Mojofire
12-23-2003, 11:51 AM
Where did you find this information? You left reference #'s which site?/
OffroadX
12-23-2003, 04:01 PM
It was posted on the xterraownersclub.com site. Some get a recall/replacement, others get a warranty extension.
rcooke
01-20-2004, 12:18 PM
In regards to the posts about the recall, I have a 2000 xterra. The power window regulator failed on the rear window, causing the motor to fail. I called Nissan (800-647-7261) customer service about the recall (NTB03-118, PU306,PU307) and they told me it only applied to 2001 and 2002 models. They have not heard about problems with the 2000. If they hear enough , themay add the 2000 models to the recall. So if you've had problems with your 2000 model, please call Nissan.
armouredcat
02-02-2004, 10:10 PM
I just got a card in the mail from Nissan saying that my 2001 Desert Runner qualified for a Window Regualtor replacement. Both doors broke within a week of each other, 10 months ago, and it looks like all the "letters of concern" that we sent Nissan were heard :) Ill post when I get the repairs made to see exactly what is covered.
Later!
-AC
OffroadX
02-03-2004, 09:52 AM
You should also get a reimbursement if you had to pay to get that fixed 10 months ago.
