1998 Intrigue Ac Bloweryarb11 07-13-2008, 11:09 PM Help!!! My AC blower is on when the keys are not in the ignition. It is killing the batery. I found the fuse to save the batery when it is parked. The main relay under the hood is good. It is between the little fuse I am pulling leading me to believe it is the switch or blower motor. This car has auto climate control. Thanks in Advance. :confused: :confused: :confused: harmankardon35 07-14-2008, 05:05 AM like many issues lately, his sounds like a faulty ignition switch...although i must admit ive never heard of the blower staying on:sly:. Hoppy2 07-14-2008, 06:19 AM I think that if you found the relay, and the fan stayed on, you have a relay that is not working. If you pull the relay, does the fan stop? Do you have continuity to the coil in the relay? dukecebrelli 08-26-2008, 08:11 PM Also have the exact same problem! I pulled out the high fuse for the blower and its saving my batt- but I gotta put it in any time I want to use the air..........ahhhh! greasyhog 08-28-2008, 07:29 PM i dont have auto climate control but my blower would stay on high when my car was off. changed the blower resistor and it fixed the problem (2000 intrigue) vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
