Re: Weird Stuff Happening 2000 Intrigue
Sounds pretty typical of the ignition switch. Some, myself included, have had luck by cleaning the external contacts on it, some even go as far as to take it apart and clean up things on the inside.
Heres instructions on how to remove it if your interested, cant really hurt anything, just takes some of your time.
http://www.automotiveforums.com/vbul...d.php?t=736656
Before you tear into that, you should also check your battery cables to make sure they are free of corrosion, pull back the boot portion as well.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
