94 Ranger ABS lightdeepsea82 07-13-2008, 01:48 AM Had to lay on the brakes in my 94 Ranger 2WD a few weeks ago. Shortly after the ABS light and brake light came on. Immidiately looked at fluid and checked for leaks. checked out OK. Not much experience with ABS so I had a mechanic try to figure out how to read the code to no avail. (He mentioned that "it could be worn pads") Thus far I have replaced rear pads, hubs and hardware, front pads, rotors calipers and hoses. The light continues to come on after a short drive and normal braking. I don't normally just randomly throw parts at a problem but in all fairness I havn't replaced anything yet that wasn't in poor condition anyway. Really could use some advice on how to pull the ABS codes or what to look for. Any help much appreciated. e_powers 07-14-2008, 06:49 PM check the abs pigtail connector and wire on the differential. this is some times the cause on others that have this problem lectraplayer 08-15-2008, 10:07 PM Also check the ABS fuse (I know, doesn't make sense, but a bad fuse will cause the ABS light to come on). What does it do when you stomp the brakes? Can you lock 'em up or does it work? toddler62 08-15-2008, 10:58 PM My 94 Ranger did the same thing when I hit the brakes hard to avoid a deer a bout 40k back. I did nothing and after a couple weeks the light quit coming on. Not Sure if I have ABS now or not But the truck stops good mash it 11-13-2008, 05:30 AM mine does it at wot Automotive Network, Inc., Copyright ©2012
