Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 07-11-2008, 11:49 PM   #1
Dart Shop
Dart Shop Normal reputation
Honda starts when only cold.
I have a Honda Legend 1990 2.7mtr. Car was fine. Started and backed out of the driveway, it cut out and wont start.
Motor turns over, wont fire. Spark at plugs, fuel is pumping and we changed fuel regulator, thats all ok.
When really cold on a morning it will start and run for 3 seconds then cut out, wen its warmer during the day, no chance at all. Just turns over.
I have very little knowledge and about as much money Would appreciate any hints at what to try, look for or to do. Its been 3 weeks now and still no change or progress.
Really would appreciate some advice.
Many thanks.
Dart Shop is offline   Reply With Quote
Old 07-13-2008, 07:23 PM   #2
wiseguy01
wiseguy01's Avatar
wiseguy01 Normal reputation
Re: Honda starts when only cold.
make sure that the air filter is not restricted cause if a motor is starved for air it will not start but on a cold day the air is much denser and then check your idle air control valve and see if the bottom main pulley turns when the distributor rotor turns if not timing belt
wiseguy01 is offline   Reply With Quote
Old 09-15-2008, 12:42 AM   #3
localnut
localnut Normal reputation
try this...when the it doesn't start, watch the check engine light. the light should come on for about 2 seconds and then go off, after turning the key to the ignition on position (not cranking). if that does not happen. you may have a main relay or and ecu problem. main relays are known to go bad.
localnut is offline   Reply With Quote
Old 09-16-2008, 12:51 AM   #4
wizbang121
wizbang121 Normal reputation
OK! HAVE YOU CHANGED YOU MAIN RELAY?
wizbang121 is offline   Reply With Quote
Old 10-23-2008, 12:59 AM   #5
Jack Zim
Jack Zim Normal reputation
It's like the opposite of mine, it won't STOP when it's cold. Refuses to go into park.
Jack Zim is offline   Reply With Quote
Old 06-10-2009, 02:39 PM   #6
1988 honda
1988 honda Normal reputation
Disconect fuel line and crank-it for a bit ...see if fuel is coming out.
had same probem some time ago. fuel pump was working when engine
was cold but not when was hot....good luck.
1988 honda is offline   Reply With Quote
Bookmarks
Google
Web AF
