Hard Shift In TrannyDark_StRanger 07-11-2008, 09:44 AM i replaced it in my 91 3.0 with a used with 36XXX 1-2 has a hard shift with a whine when i increase/decrease rpms any clues? backerm1 07-13-2008, 08:46 AM could be water in ATF. try getting a flush and putting a friction modifier additive in there. Dark_StRanger 07-13-2008, 09:53 PM could be water in ATF. try getting a flush and putting a friction modifier additive in there. I did ive when i got it i replaced everything all the seals and cleaned everything out then added some lucas into the pan and fill her up the rest could it be the TC or the fly? backerm1 07-14-2008, 06:28 PM could it be the TC or the fly? did you use your old converter? how bad is it doing it? Dark_StRanger 07-17-2008, 06:05 PM no i used a re-man. one...its not that bad...im not worried about it but id like to solve it you know backerm1 07-17-2008, 07:50 PM its probably something internal. i'd take it to a tranny spec. shop. they might be able to fix it without taking it out Automotive Network, Inc., Copyright ©2012
