Several Questions of a newbiesoup1207 07-10-2008, 10:27 PM :eek::eek::eek::eek: sorry to ask so much, please forgive and answer me. :eek::eek::eek::eek: What is the signal of engine overheat? is it over half of the engine temperature indicator? I hope to know it to slower down the speed if it happen In what condition I have to turn off the over-drive function please? Is the supercharge oil a kind of engine oil? I guess not and want to make sure... I just bought my 1995 previa. The second hand agent said his friend(who's a car repairer) has added oil and fluid for me. I suspect if he added the s/c oil too. Is there any risk the repairer added some non s/c oil into the s/c oil tank? Where can I check the level of the s/c oil? Thank you very much. :eek::eek::eek::eek: jdmccright 08-01-2008, 02:01 PM Somewhat late, but to answer your questions: When it gets into the red and the engine light comes on, you should stop and let the engine idle with the heater blowing hot...windows down to keep you from baking. Or get out and stretch. Pointer at the half-way mark would be normal. Overdrive is usually turned off when going up extended hill climbs...this helps prevent the continuous "hunting" that the transmission does to find the right gear. You may notice a slight increase in engine temp during climbing, but don't worry until it hits the red. Constant runs like this though will necessitate more frequent transmission fluid changes. I've never heard of "supercharge oil". There are many brands and types. If you get yours changed at a reputable place then no worries. Any brand that meets the car's specs in the manual is fine. I would recommend asking for the "high-mileage" version of their oil if they offer it...it may be a few extra dollars but I'd say worth it. You are referring to a supercharger that may be an installed option on your engine (that's what the "S/C" emblem on the back denotes). The supercharger does have its own oil reservoir, and uses a specific type (Genuine Toyota Supercharger oil 08885-80108, or equivalent...I've heard Castrol Syntec 5W-50 oil is acceptable as a substitute). The dipstick is a little yellow screw-on cap WAYYY down in the engine bay. Probly best left to a mechanic, but don't let them skip over checking it! Hope this helps! vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
