Dodge Ram 50 1984 no spark
ponchonutty
07-10-2008, 10:21 PM
Checked everything. Even replace the distributor. Noticed there isn't a ground pulse going to the coil. The coil has power but it isn't getting the signal in the blue wire to pulse. If I start tapping the signal side of the coil with a jumper wire to ground it'll sputter and try to fire when cranking it over.
What I need to know is where that blue wire (changes to white/black in first plug) goes to or what controls it. Do I have an issue with the computer or is it something else????
jpb53
07-11-2008, 01:06 PM
On line manuals in caravan section could be some help.
rhandwor
08-05-2008, 09:17 PM
In my wiring diagram the DK blu is the positive. Ignition switch,alternator,voltage regulator 6 pin connector,spark control computer,egr solenoid,air sw solenoid. On a Ford they always pulse the negative Blk YEL wire. It also goes to the spark computer. I would suspect the spark computer as the signals from the distributor also go to it. As you have a six pin connector I would ohm the wires between the coil and spark computer. Same color all the way.
You can send me a private email and I can scan and fax a copy to you if needed.
ponchonutty
08-07-2008, 09:56 PM
Thanks. What I've found is that I am not getting any output from the computer so I suspect that is the problem. Unfortunately a new computer is more than what the truck is worth.
rhandwor
08-07-2008, 10:26 PM
I would get the number off of the computer and call a few scrap yards. Normally they give a 30 day warranty or they replace it free. At least you would get a lot more than scrap for the truck. I've bought used ones for family vehicles and they lasted until I was ready to sell.
