3.0l overheatinggbeach 07-09-2008, 01:22 PM 98 caravan after sitting about 10 minutes idling with a/c on all of a sudden temp gauge starts going up. Revved up engine and started coming down. Fans are working fine. Kicking on, but temp still goes up. Water pump is fairly new, no leaks, but reservoir tank was low. could I have a thermostat problem. Just happened at lunch going to check radiator level when it cools down. gbeach 07-09-2008, 03:12 PM well was low on antifreeze in the radiator. gbeach 07-10-2008, 01:05 PM well after filling up, now I am getting about 5 drips after parking. looks like coolant. water pump only has about 15 k on it. can't see where it is coming from. near the bottom of the crankshaft area. not big enough to trace gbeach 07-10-2008, 01:40 PM well after filling up, now I am getting about 5 drips after parking. looks like coolant. water pump only has about 15 k on it. can't see where it is coming from. near the bottom of the crankshaft area. not big enough to trace inafogg 07-10-2008, 01:53 PM would be best to check while system is under pressure.sometimes using a mirror to check the pump is helpful.what brand wp was put on??if it was a cheaper brand then it maybe the water pump gbeach 07-10-2008, 02:10 PM what a dumbass I am. I didn't even think of using a mirror to help. very good idea. I am going to do that when I get home. Automotive Network, Inc., Copyright ©2012
