Re: my 96 jetta is getting too much fuel
As far as the MAF sensor is concerned get some MAF sensor cleaner and clean it. This is just good practice. As far as the error code is concerned, check your wiring harness to your computer. Clean the contacts, you may want to use dielectric grease. The error code indicates either an open circuit or a short going from the computer to the battery + terminal. I'd also make sure that the pump that was installed was the correct pump. VW switched them almost every year for awhile. If your computer doesn't function right, you won't get proper fuel mixtures.
