I have a 1977 delta 88 olds , who's in the need for a Speedometer ( needle was knocked off while changing dash bulbs) . It has been impossible to locate parts. Is there a compatible part for this model, also if someone knows how to fix the needle , glueing has not work and the part is thought to be too small to weld back in place.
Welcome to AF. I would try some of the local salvage yards, I believe 77-79 is the same, also Hemmings News lists companys that exchange/repair speedos. BTW, reduce your font, thanks.
Also if the salvage yard has a Hollander Interchange manual, it may say what other GM models may work as well, increasing your chances of locating one.
__________________ Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
It's Oktoberfest time !!
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
