Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Buick > Riviera
Old 07-01-2008, 08:30 PM   #1
BuffMike
BuffMike Normal reputation
1995 Riv front end problem - new member
Hi, Just joined the forum. I recently acquired a 95 Riviera. The car is in great shape except I have two issues maybe someone can help with.
1. When going over sharp bumps or potholes I get a reverberation and kickback that can be felt in the gas pedal. I have been trying to narrow it down and it seems to be mostly when the bumps are hit with the right front wheel.
2. When idling in drive such as at a stoplight there is a rattling, almost like a sack of rocks coming from the engine compartment accompanyed by some vibration. If I give a little gas, keeping my foot on brake, it goes away. Does not happen anytime else while driving but I can hear it briefly when I turn the engine off.
Any suggestions would be greatly appreciated.
Mike
BuffMike is offline   Reply With Quote
Old 07-03-2008, 08:57 PM   #2
HotZ28
AF Moderator Elite
HotZ28's Avatar
HotZ28 +50
Re: 1995 Riv front end problem - new member
Have you checked the Trans or motor mounts, to see if they are broken.
“Ye shall know the truth and the truth shall set you free."
HotZ28 is offline   Reply With Quote
Old 07-03-2008, 09:46 PM   #3
BuffMike
I havent had anything checked yet, was looking for suggestions first.
Old 07-05-2008, 09:38 AM   #4
HotZ28
AF Moderator Elite
HotZ28's Avatar
HotZ28 +50
Originally Posted by BuffMike
2. When idling in drive such as at a stoplight there is a rattling, almost like a sack of rocks coming from the engine compartment accompanyed by some vibration. If I give a little gas, keeping my foot on brake, it goes away. Does not happen anytime else while driving but I can hear it briefly when I turn the engine off. Any suggestions would be greatly appreciated. Mike
Be sure to check the outer ring on the harmonic balancer, it has a rubber bond between the inner & outer ring. When the rubber bond breaks between the two, it will make a metallic knocking sound at idle. While the engine is cool and before starting, place your hands on the outer ring and see if it can be moved back & forth. If so, you have found the problem.
Bookmarks
Google
Web AF
