1999 Suburban wont start after replacing batt.
GMCjet52
06-30-2008, 02:03 AM
Here's the situation:
My 99 1500 Suburban has been parked for 3 weeks. I left the interior lights on which killed both the batteries. I guessing they might have lasted for about a week which means the Suburban probably sat there for a couple of weeks with completely dead batteries.
I replaced the batteries and now it will not stay running. It cranks up and runs for about a second then dies.
I'm thinking it might have something to do with the passlock system, but the security light is not lit up.
What could this be?
MT-2500
06-30-2008, 10:33 AM
Go threw the relearn procedure.
Key on for 10 minute untill security light goes out and then off and on 3 times.
Then off and see if it will start.
GMCjet52
06-30-2008, 11:50 AM
Didn't work, keep in mind the security light is not on.
The Suburban worked perfectly when I parked it.
MT-2500
06-30-2008, 01:18 PM
Does it come on key on?
And go off or just not come on?
Also.
They to lock and unlock doors with key.
GMCjet52
06-30-2008, 04:59 PM
Also.
The security light doesn't come on like the others (anti-lock, check engine, etc...) do with the key forward. I've never seen it lit up. It is there though, I looked for it with a flash light.
I already tried to lock and unlock the door with a key, just the driver's side.
Any ideas before I have to sacrafice myself to the stealership?:eek7:
MT-2500
06-30-2008, 07:39 PM
Sounds like it is time for a body capable scanner.
If you do not want to go to dealer look around for a good regular repair shop that has a good body/engine capable scanner.
MT
