A/C leaks?
iski
06-27-2008, 04:23 PM
I have water on the pass mat. What can I due? Where is the cabin filter?
inafogg
06-27-2008, 05:51 PM
it sounds like the evaporator drain is clogged.take a look passenger side firewall area should be rubber hose pointed down.using a sutible tool try to clean it out.if its too clogged you may need to remove casing inside car to clean.Good Luck
