Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Tracker
Old 06-26-2008, 11:16 AM   #1
angus10
angus10 Normal reputation
99 tracker front diff ?
The right front push in drive axle is loose where it goes into diff housing. Is it most likely the diff housing bearing ? Or will replacing the drive axle correct this? And is the bearing and seal easily replacable from the outside or does the diff have to come out and replace from inside? TIA
98 Ram 1500 4x4
Hypertech
Magnaflow Cat.
Flowmaster American Thunder W/super40
14x3 AF mod
angus10 is offline   Reply With Quote
Old 06-27-2008, 02:17 PM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: 99 tracker front diff ?
Up and down or in and out play.
Is it giving problems.
Get a dial indicater on it and tell us how much play it has.
Right side may be a bushing on axel shaft but not sure on that.
Pull axel out and look at it for wear first.
Then check parts book for bushing or bearing.
MT
MT
MT-2500 is offline   Reply With Quote
Old 06-27-2008, 04:56 PM   #3
angus10
Thanks for responding MT, the play is up and down and front to back.
98 Ram 1500 4x4
Hypertech
Magnaflow Cat.
14x3 AF mod
Old 06-27-2008, 07:20 PM   #4
MT-2500
AF - Advisor
MT-2500's Avatar
How much movement?
Some play is normal.
Is it giving you any problems?
Is the seal leaking?
MT
Old 06-28-2008, 06:37 AM   #5
angus10
Hi thanks for your time. Yes there is a prob, it's vibrating up front somewhere and that is all I can find that seems loose. The driveaxles seem ok, as do the wheel bearings. The seal does have a leak but it is not too bad as in its not dripping and when I check the level its never low.
98 Ram 1500 4x4
Hypertech
Magnaflow Cat.
14x3 AF mod
Old 06-28-2008, 06:39 AM   #6
angus10
BTW, it moves more than an 1/8" .
98 Ram 1500 4x4
Hypertech
Magnaflow Cat.
14x3 AF mod
Bookmarks
Google
Web AF
