Burning wire smell from A/C..paulf717 06-26-2008, 10:32 AM I have a 1996 Grand Caravan. Lately, I have been getting a real strong odor of burning wires coming from the A/c inside the van. When I run the A/C??? Its getting progresively worse. I'm worried about the van catching on fire. Can someone please give some advice. Thanks :frown: RIP 06-26-2008, 01:54 PM If you can smell it with just the blower fan on and the A/C off I would suspect the blower motor is drawing too much current and overheating. If you smell it only when the A/C is on I would suspect the climate control panel. Remove it and inspect the connections on the back. brocsbar 06-26-2008, 04:10 PM many caravans have this problem and if you let it go your guages and spedo etc wont work. take out the 4 screws that hold on the a/c stuff and unplug it and inspect for a burnt terminal I JUST did one 5 min ago. Clean it up and plug back in or get one from the junkyard. paulf717 06-27-2008, 08:53 AM I'm not sure where the 4 screws are, are they on the control panel. thanks RIP 06-29-2008, 06:19 PM Yes they are on the control panel behind the black plastic bezel that surrounds the panel. Automotive Network, Inc., Copyright ©2012
