'02 Alero wipers skipping around
Varuna
06-25-2008, 10:58 PM
Whenever I use my wipes on mist, or any itermittent speed, they skip around randomly. They'll go up part way and stop for a second, them move to the top and stop for a bit, and do the same going down (give or take, as I said it's random).
I'm guessing it's the relay, but I was just wondering if anyone else had encountered this and knows a definite fix before I start changing stuff out.
Thanks!
xeroinfinity
07-01-2008, 04:22 PM
Could be a loose motor or the plug is dirty/bad or loose(ground) , here is a link with some pics on the rermoval.
http://www.automotiveforums.com/vbulletin/showthread.php?t=693310
lpstudio
07-27-2009, 05:24 PM
I have the same problem with my 02 alero wipers only on intermittent did you get yours figured out?
xeroinfinity
07-31-2009, 03:59 PM
If you've replaced the wipers and it's still skipping, you're probly going to have to inspect the works to find out what's going wrong.
undersc0re
08-01-2009, 08:45 AM
I just fixed mine, made it worse at first when I took the board apart that was attached to the wiper motor to try and fix it. I got a whole new wiper assembly for 100$ after that, I guess the electronics on it screws up, and it goes wacky, the motor is confused about the stop spot etc.... You WILL need a wiper puller to make your job much easier or possible at all! Don't put any pressure on the edge of your windshield or snap crackle pop!
xeroinfinity
08-01-2009, 02:56 PM
Yeah it seems Aleros are more prone for the circuits malfunction out there, not seen many Grand Ams with this issue.
And the wiper arms are on there pretty tight !
Ive seen cracked winshields and cracked cowels from poeple trying to pry them off wrong.
That was a good deal on that unit undersc0re. :thumbsup:
