Plastic gas tank repairsrhandwor 06-25-2008, 03:18 PM Some friends of my wife said kids are drilling a hole in the bottom of the tank to get gas. Are their any repair procedures to fix a hole if needed. Any epoxies work for this. What would you suggest junk yard tank or repair? If installing a new fuel pump how much support do they need? MT-2500 06-25-2008, 03:50 PM OH MY BETTER CATCH THEM KIDS BEFORE THEY BURN THERESELF UP. If they are using a electric or cordless drill They will be on fire one of these times. They make some good epoxy repasir kits. You need the type that is flexable for plastic tanks. If the hole is not in fuel pump area jack one end of it up soe no fule seaps out and try a metal screw in hole with a washer and some kind of seal on it . Then epoxy over screw and washer. Good comp insurance should cover things like that or even give you a new fuel tank. Good luck MT wafrederick 06-26-2008, 08:19 AM Plastic gas tanks are not repairable.The easier way is to replace it. rhandwor 06-26-2008, 09:21 AM Thanks I hope I don't need to if it happens I will try the MT-2500 idea I have used a faucet washer and self tapper on metal tanks. When I had a garage you don't want gas dripping on the black top parking lot. You definately don't want it in the garage with smoking mechanics. I've caught them smoking when putting a fuel pump in. Just getting to a junk yard and scheduling the work takes some time. I don't do work when its above 95 or 100 degrees. Thanks again j cAT 06-26-2008, 09:41 PM Thanks I hope I don't need to if it happens I will try the MT-2500 idea I have used a faucet washer and self tapper on metal tanks. When I had a garage you don't want gas dripping on the black top parking lot. You definately don't want it in the garage with smoking mechanics. I've caught them smoking when putting a fuel pump in. Just getting to a junk yard and scheduling the work takes some time. I don't do work when its above 95 or 100 degrees. Thanks again these tanks are not repairable do not fix any gas tank must buy new tank unless a scrap yard will sell you one....call gm tech support they will repeat my message... muff34 06-29-2008, 12:31 AM call gm tech support they will repeat my message...of course they will $$$$........lol. Sorry Couldn`t help myself j cAT 06-30-2008, 02:58 PM of course they will $$$$........lol. Sorry Couldn`t help myself I know some idiot will try to fix a plastic GM gas tank , and then it will go up in flames....maybe your vehicle will be parked next to this idiot... doctorhrdware 07-19-2008, 06:16 PM I remember as a kid, this mechanic was repairing a gas tank and ended up burning down his garage. I believe that is was a metal tank and was using a welding torch. silicon212 07-19-2008, 06:40 PM I've used JB Weld epoxy to fix a seam leak on a metal tank, but it says right on the plastic tank "NOT REPAIRABLE". wafrederick 07-19-2008, 06:47 PM It is much easier to replace a gas tank than fixing it.The advantage is that you fix it once instead of 3 or more times.A guy in my area was killed last year,cutting a drum with a torch that had racing fuel vapors in it and it blew up his garage. Automotive Network, Inc., Copyright ©2012
