Re: Engine Revving/Transmission Disengaging
I agree, it sounds like a fluid level problem. Did the shop remove the T-case from the tranny? Look at the back of the tranny, were the transmission and t-case bolt together, is it wet? This is a prone area for leaks. What sensors did they change? If it is leaking, then I would take it back to the shop and have them remove the t-case and install a new seal. Most seals are a fiber type, but gray RTV will work well if everything is clean.
