Radiator Fan & A/C Pressure Transducerjpb53 06-24-2008, 09:23 PM Temp readings are from ECT (engine coolant temp sensor) Pressures are from A/C pressure transducer Fan low speed 104 C (220 F) 1,724 Kpa (250 Psi) High Speed 110 C (230 F) 2,068 Kpa ( 300 Psi ) Fan turns off at 101 C (214 F ) or when Pressure drops below 1,710 Kpa (241 Psi ) Low speed is at 30% speed and will increase from 31% up too 100% duty cycle depending on the temp or pressure inputs. Transducer Voltage 0 Volts = transducer faulty or no voltage from PCM .150 to .450 volts = Transducer Good/low pressure cut out condition .451 to 4.519 volts = normal operating condition 4.520 to 4.850 volts =Transducer good High pressure cutout condition 5 volts = Transducer Faulty Wire Colors Dark Blue = Switch output to PCM Violet/ White tracer = 5volt supply from PCM to transducer Black/ Lt Blue tracer = sensor ground Hope this helps and clears up some problems for those trying to fix fan and A/C problems. Hope it makes sense. Fan comes on with gauge at approx. 9/16 to 5/8 gauge reading. RIP 06-25-2008, 03:41 AM And if we had a moderator it could be a sticky or permanent file at the top of the forum. Thanks for the info. jpb53 07-21-2008, 12:13 AM bump jpb53 09-29-2008, 07:18 PM bump Automotive Network, Inc., Copyright ©2012
