1992 4.0 Jeep Cherokee Won't start in park when parked on inclines?
Google
Web AF
doug2060
06-22-2008, 12:15 AM
My new used 92 Cherokee 4WD will not start in park when the weight of the vehicle is leaning forward (such as on a hill). I'm sure it is most likely the neutral safety switch but I'm not sure what I should do about it if anything. It will start fine if I pop it in neutral plus there is a push button for the starter under the hood. Is anyone familiar with this issue?
Bobbywolf
06-22-2008, 05:28 AM
This is a very well known problem with the NSS. It can make starting intermittent, reverse lights intermittent, and a few other problems. It isn't too big of a deal to remove it, split the case on it and clean it up and regrease it. Do a google search, or even on here for cherokee nss and you will find all the info you need. I did the job myself, and it wasn't too bad.
AlohaBra
06-23-2008, 09:18 AM
You should rebuild the NSS...other issues will eventually surface.
doug2060
06-23-2008, 03:39 PM
I've had to rebuild the NSS in a Grand Am before so I know it's easy to do. I hope it's not in some hard to reach position under there. Thanks.
fredjacksonsan
06-23-2008, 11:20 PM
There IS a rebuild thread or reference in here.
doug2060
06-23-2008, 11:28 PM
I found it. I'm actually getting ready to go put it back in the next hour or so. It looks like the old grease had gotten hard in it. I broke a small piece of the plastic housing part off. Instead of gluing it back on I put some Black RTV in it's place. I'm sure it will be fine. I'll post another reply when I'm done.
fredjacksonsan
06-23-2008, 11:29 PM
Found it...
http://www.automotiveforums.com/vbulletin/showthread.php?t=884255&highlight=nss+cleaning
That should get you started. You might also want to read:
http://www.automotiveforums.com/vbulletin/showthread.php?t=769129&highlight=nss+cleaning
edit: Damn! Too slow. :D
doug2060
06-24-2008, 12:43 AM
Found it...
Thanks for your help. This seems to be a very common problem. Someone will come along with the same problem and may be lucky enough to find these posts.
Here is another link that was very helpful.
http://www.go.jeep-xj.info/HowtoNSSrebuild.htm
I believe one of your links lead to the website I got it from.
My issue is resolved. I tested it in several positions and it started perfectly every time. Reverse lights and all. Thank you to everyone for your replies.:smokin:
It was easier to get on than off. I bet I spent 30 minutes trying to get a zip/cable tie off.:cwm27:
Google
Web AF
