Head Gasket?
Buudha
06-21-2008, 02:10 PM
So earlier today I opened up my hood on my 99 Grand Am Se 3.4L and noiticed there was a puddle of coolant on my transmission. I looked around the engine a little and noticed it was not only on the transmisson, but also on the engine near the EGR (not coming from it) as well as on the left side of the engine near the belt. Here's a few pictures I took.
http://boxstr.com/view/full/2445055_skklu
http://boxstr.com/view/full/2445058_i0spb
http://boxstr.com/view/full/2445059_lp7eo
http://boxstr.com/view/full/2445060_wr32h
http://boxstr.com/view/full/2445061_vxr3u
http://boxstr.com/view/full/2445062_ths7o
http://boxstr.com/view/full/2445065_nutiw
xeroinfinity
06-23-2008, 10:06 AM
Welcome to AF.
Sounds like a lower intake gasket leaking, typicalon the 3.1/3.4's, how many miles on this 99 GA ???
From the pics, it also looks like you are leaking oil out the LI gaskets.
Have you noticed any coolant in your oil or oil in your coolant ??
Here is a link for the LIM procedure.
3400 SFI LIM Gasket Procedure (http://www.automotiveforums.com/vbulletin/showthread.php?t=688030)
Buudha
06-23-2008, 10:23 AM
It's the 3.4L. I have over 110,000 miles on it. I'm in the process of running some tests. So far it's not overheating, but I do run out of coolant quite often (about every two weeks). It does kinda look like there is some coolant in the oil but it kinda hard to tell because the oil had a slight tint since I put it in there about a month ago. I replaced the intake gasket with the new one they had came out with around november. I was looking at that oil on the sides and did notice there was a little on the ground.
xeroinfinity
06-23-2008, 10:36 AM
Humm... if you just repalced the LIM then it should not be leaking again unless the torqu specs were off....
You say you did use the updated gasket kit ?
Have you done a compression test ?
Buudha
06-23-2008, 12:55 PM
No I didnt do a compression test. Whenever I get a chance I will take another look at it. Chances are my torque specs were off by a bit. I know that it doesn't take much to screw the whole assembley up.
