'00 ga gt still cant figure out headlight problemjhals21 06-20-2008, 10:39 PM right front tail light is really dim. The driver side headlight is fine. any ideas. jhals21 06-20-2008, 10:41 PM The passenger side headlight is very dim. I tried a new bulb but that one does the same thing. The driver side works perfect, as well as all the signals and fog lights. SVS light is on. any ideas xeroinfinity 06-21-2008, 04:59 AM Your two threads have been consolidated. I assume you meant right front headlight.... in your first post. Check the plug & terminals & wires to the headlight, also check the ground wires that connect to the inner front fender, or front radiator suport. I would check the fuse(s) for the head lights and make sure thier's no corrosion on the fuse terminals. Could be a relay for the DRL's or ALC bad causing your SVS, but you may need to get it scanned to figure out why it's on. I'd check those terminals for corrosion too, thier all under the hood. jhals21 06-21-2008, 10:06 AM which side is the grounds located on the passenger or drivers side of the bumper or radiator support. xeroinfinity 06-23-2008, 10:51 AM you cant realy get to them as they are hidden under everything. Their are two grounds behind the battery on hte front support. Here is a wire diagram for the headlight systems, I'd check those fuses and relays first tho !! http://www.automotiveforums.com/vbulletin/showthread.php?t=758919 Automotive Network, Inc., Copyright ©2012
