Brake light Problemsd_crosson 06-19-2008, 07:27 PM So my 2000 grand am Se, has the emergency brake light on, even though the E-brake is off. I checked the little switch under the middle console, it was fine, so i tested the contanuity from that plug of the switch to the frame and there was contanuity, so i guess it is grounded, then i followed the wire all the way from that switch to the dash and couldnt find anywhere where it was pinched or grounded, any thoughts on this?? xeroinfinity 06-19-2008, 11:02 PM Sounds like the switch inside the shifter console is sticking or bad. Have you also tried lifting and releasing the e-brake a few times ? d_crosson 06-19-2008, 11:28 PM Ya, i looked at the switch and nothing was wrong with it i even unhooked the switch and the light was still on. xeroinfinity 06-19-2008, 11:37 PM Ok then check your brake fluid level, probly should hav done this first. If thats ok you'll probly have to have it scanned with an ABS capable tool to find out why its on. Automotive Network, Inc., Copyright ©2012
